GDL object moving
We are doing a 4D project with the plug-in in ArchiCAD 14. I would like my cranes (3ds-converted objects) to move as the simulation runs with one or more cameraes-
It must be a ROTz..... something like this with a 4x4x4 block:
BLOCK 4,4,4
ADDx 2
ADDy 2
ROTz (N_+1)/(P_+1)
del 1
HOWEVER, it does not work - what went wrong?
Thanks.
10 Replies 10
fuzzytnth3
Did you tick the box for rebuild model for each frame in the Save fly through settings?
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
Oh yes, but still there is no movement...Is my script correct? Tried to look something up in the COOKBOOK without any luck although there a movements in many of the samples:-)
try to place the BLOCK command after thr ROTz transformation.
I think it may helps.
best regards,
Nope, did not help.
Frank Beister
try this:
_ang=360
ROTz (GLOB_FRAME_NR+1) * _ang/(GLOB_LAST_FRAME+1)
The BLOCK command must be after the ROY but before the DEL.
There is also a broblem with your maths.
ROTz (N_+1)/(P_+1) will only rotate by a minute amount each time
Just use ROTz N_ to rotate one degree each frame.
YEP, it is working now - my block is moving fine with:
ROTz N_
BLOCK 4,4,4
BUT not around its own axis in the middle of the object....How to?
You will need to ADD by the negative value of half the block size then place the block then DEL to put the cursor back to the original position.
ADD -2, -2, 0
BLOCK 4,4,4
DEL 1
THANKS, Barry!
Very good basic GDL!
