GDL - variable FILL BACKGROUND
I am new to GDL. I'm not able to add the variable FILL BACKGROUND sript in 2D.
[/img]
4 REPLIES 4
It's not clear to me what you are trying to do (and the image isn't helping - it's blurry and just seems to be a generic main window from an autop-generated part).
If you are trying to add a parameter to the list the "FILL BACKGROUND" won't work since space characters are not allowed in variable names. The standard approach is to use and underscore character to substitute, ie: "FILL_BACKGROUND"
Otherwise please be a bit more specific about what you are trying to do.
I created an object following a tutorial GSM ancient site of Graphisoft. I added the controls to pen and fill, but as my knowledge is limited, could not apply a control for the background fill in the script. Can you help me?
Here the image of the 2D script
David Maudlin
judsonarq:
I don't think the pen for the background fill of a Fragment (a fill drawn in the 2D Symbol window) can be parametric, only the foreground pen and fill type can be controlled. So you will need to use the POLY2_B command in the 2D Script to numerically define the fill and have control over its background pen.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
