ā2008-08-21 04:35 PM
ā2008-10-01 05:08 AM
ā2008-10-01 12:04 PM
ā2008-10-01 01:15 PM
ā2008-10-01 01:19 PM
Barbara wrote:This bug has been visible in the ArchiCAD API since ArchiCAD 11. If you change the lib part associated with an API_ObjectType and save with ACAPI_Element_Change, everything appears to work perfectly. The updated object is illustrated correctly in 2D and 3D, you can edit parameters, and you can duplicate it by dragging or copy/paste. However, if you save and reopen, all the objects (even the copies) will have reverted to the previous object. The only work-around was (through the API) to delete the original object and create a new one in its place.
We have verified Duane's steps to replicate this problem and had the same experience as described. Our developers will fix this bug as soon as possible.
ā2008-10-01 04:57 PM
ā2009-01-02 06:18 PM
Barbara wrote:REALLY? So there will be another hotfix for AC11 at some point?
We are fixing this bug in version 11 as well.
ā2009-01-04 08:02 PM
ā2009-01-05 04:48 PM
laszlonagy wrote:Wow -- thanks Laszlo.
Yes, it seems like there will be. Barbara in another thread mentioned that there will be a new AC11 hotfix:
