Eduardo Rolon
Garden Works library from GDL Central problem with AC09
I was using some ArchiBAM trees from the Garden Works Library on AC8.1 with no problems. I just opened the file in AC09 and when I switch to the 3D window I get the following message...
Cannot DEL transformation above TOP
at line 205 of file Pine2_GWL.gsm.
It happens for most of the trees but not all. It also happens when importing trees from that library to a new AC09 model. It is annoying and I don't know if I can safely ignore it. Pity the time GS spent updating those library parts. Back to finishing the site pres in AC08.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
3 Replies 3
Hi
Check the http://archicad-talk.graphisoft.com/viewtopic.php?t=2933 for discussions regarding you problems. Hopefully the update will arrive soon.
This error can, but typically does not, cause a problem with the generation of the 3D part. Take a look at what you get in the 3D window. If it looks good it is good.
Make sure that you have "Interrupt with error messages" turned OFF in Options > Preferences > Imaging and Calculation. (I'm guessing you've already done this.)
Eduardo Rolon
I did ...
AC29 US/INT -> AC08
another Moderator
