2004-10-12
12:30 AM
2023-05-24
12:12 PM
Rubia Torres
another Moderator
2004-10-13 09:37 AM
It happens for most of the trees but not all. It also happens when importing trees from that library to a new AC09 model. It is annoying and I don't know if I can safely ignore it. Pity the time GS spent updating those library parts. Back to finishing the site pres in AC08.Check the
2004-10-13 02:10 PM
ejrolon wrote:This error can, but typically does not, cause a problem with the generation of the 3D part. Take a look at what you get in the 3D window. If it looks good it is good.
Cannot DEL transformation above TOP
at line 205 of file Pine2_GWL.gsm.
2004-10-13 02:57 PM
Matthew wrote:I did ...
Make sure that you have "Interrupt with error messages" turned OFF in Options > Preferences > Imaging and Calculation. (I'm guessing you've already done this.)
another Moderator
