Get section view of GDL object.
Hi everyone,
I have made a new parametric GDL object and have successfully created the plan and 3D view for it.
The problem comes when I try to create the section view for the object; it doesn't show the internal structure of the component (it only displays a black surface). I have used GLOB_CONTEXT but I haven't had any success so far.
Would anybody be able to suggest any solutions for me?
Thanks
Stickinsect7
10 Replies 10
Thank you for all of the help, it has been successful!
I spent some time doing as Olivier and Erich suggested (using the SECT_FILL command to define the seperate fill areas) and I have now got a detailed section through the object.
Thanks again for all the help, it's greatly appreciated!
