I have made a new parametric GDL object and have successfully created the plan and 3D view for it.
The problem comes when I try to create the section view for the object; it doesn't show the internal structure of the component (it only displays a black surface). I have used GLOB_CONTEXT but I haven't had any success so far.
Would anybody be able to suggest any solutions for me?
Thank you for all of the help, it has been successful!
I spent some time doing as Olivier and Erich suggested (using the SECT_FILL command to define the seperate fill areas) and I have now got a detailed section through the object.
Thanks again for all the help, it's greatly appreciated!
