2008-12-10
10:37 PM
2023-05-24
11:58 AM
Rubia Torres
2012-09-11 03:07 AM
2012-09-11 03:23 AM
2012-09-11 10:16 AM
2012-09-11 10:19 AM
lec1212 wrote:Levente has contacted those guys and fixed it for them.
Thanks Levente for getting my subscription fixed/listed so I could download MJO-16.
Looks like a few others could use some help also.
2012-09-11 12:29 PM
lec1212 wrote:It's a bit worrying that all the MJO images, macros, etc are all duplicated for doors and windows - it will probably cause a library loading complaint about duplicates every time. It could also cause problems when you add your own joinery presets to the lists of standard configurations. If the Library Manager chooses to load one list on a particular day and then the duplicated list on another, custom configurations will seem to disappear.
Seems I had to also load Modular Door/Window parts.
2012-09-11 12:42 PM
2012-09-19 01:38 AM
2012-09-19 03:57 AM
Ralph wrote:It does.
It's a bit worrying that all the MJO images, macros, etc are all duplicated for doors and windows - it will probably cause a library loading complaint about duplicates every time. …
another Moderator
2012-09-19 04:39 AM
ejrolon wrote:I believe the latest hotfix is supposed to address the problem of duplicate macros when you download separate objects from BIMcomponents that use the same macros.Ralph wrote:It does.
2012-09-19 04:40 AM
aahatimo wrote:You will need to download the Modular Window object as well through the Window tool.
i now have the modular door object, thanks!
but now the modular window does not show up as an option.
are there more parts of the mjo?
