2025-12-02 05:03 PM - edited 2025-12-04 03:03 PM
I always thought that the interesting thing about the Global Library is that it's independet of the Archicad Version Running.
With Archicad 28 the Global Library had no "28", now it has become the "29" and I'm a bit confused because I thought the Global Library Update Version would be independent of the Archicad Version Nr.
My simple question is ... It's the Global Library for Archicad 29 comppatible with Archicad 28?
Will this be like this in the future? Global Library for Archicad 35 will be compatible with Archicad 28?
It's very Important for me to get some clarity about this, to configure properly how the Libraries are organized in the BIMcloud.
I also think the Mappiing Values of the Library 29 Update 1 are still not Online, maybe somebody can confirm it.
Thanks in advance
Solved! Go to Solution.
2026-03-26 02:15 PM
Hi Gariel, Could you please show me the Python script for the mapping values you mentioned? Cause I didn't find the py file that GS mentioned in one video.
2026-04-24
12:22 PM
2026-04-24
10:18 PM
Hi @Funfun Yan,
sorry I didn't answered sooner.
HEre is my Script, I use it to edit all attributes to add 9000 to the index-Nr. (becase don't use the Standard Graphisoft Attributes in our office) and it defines some exceptions to this rule (becase some Standard GS Attributes attributes can't be deleted).
You can copy this text and put it in the text-Editor, save the file with the extension *.py and you can run it with Microsoft Visual Studio Code or other Coding Applications.
Since not so long there a new community tool to edit the json files. Here you can find it
The Evolution of Editing Object Defaults in Librar... - Graphisoft Community
I hope this helps
SCRIPT START
import json
import os
# Define the directory containing the JSON files
directory = r'C:\Users\gabriel.gordillo\Documents\JsonEDIT_Bearbeitung'
# Define the types and exceptions
types_to_edit = {
"BuildingMaterial": {
"skip": [0],
"special": {35: 9083, 37: 9015}
"Material": {
"skip": [0],
"special": {}
"LineType": {
"skip": [0, 1],
"special": {}
"FillPattern": {
"skip": [0, 22, 23, 24, 64, 65, 140, 141],
"special": {18: 64, 108: 64}
"Profile": {
"skip": [0],
"special": {}
# Function to update values based on type and exceptions
def update_value(entry):
entry_type = entry.get('type')
if entry_type in types_to_edit:
exceptions = types_to_edit[entry_type]
value = entry['value']
# Check for special cases
if value in exceptions['special']:
entry['value'] = exceptions['special'][value]
# Check for values to skip
elif value not in exceptions['skip']:
entry['value'] += 9000
# Iterate over each file in the directory
for filename in os.listdir(directory):
if filename.endswith('.json'):
file_path = os.path.join(directory, filename)
# Load the JSON data from the file
with open(file_path, 'r') as file:
data = json.load(file)
# Update each entry in the JSON data
for entry in data:
update_value(entry)
# Create a new filename with "_Index9000er" appended
base_name, ext = os.path.splitext(filename)
new_filename = f"{base_name}_Index9000er{ext}"
new_file_path = os.path.join(directory, new_filename)
# Write the updated data to the new file
with open(new_file_path, 'w') as file:
json.dump(data, file, indent=2)
print(f"Updated {filename} to {new_filename}")
print("All files processed successfully.")
