2006-01-16
08:54 PM
2025-01-02
03:52 PM
Molinda Prey
2006-01-17 05:18 AM
jdrulon wrote:Transfer the parameters (CTRL ALT syringe) to the preview picture in the bottom left of the Library manager
Is there a way to change all the trees from one type to another without losing the individual sizes?
2006-01-17 06:17 PM
2006-01-18 05:40 PM
2006-01-18 05:45 PM
jdrulon wrote:Djordje's solution does make all the trees the same.
Thanks for the help. I tried what you suggested but it seemed to changed all the trees to the same size. I must be doing something wrong. Do you use the control alt key first to absorb the information on one tree or do you select all trees and do what you suggest? Do you need to absorb the information one tree at a time or can it be done globally?
Thanks again in advance for the help.
2006-01-20 12:31 PM
TomWaltz wrote:Only if all are done at once.jdrulon wrote:Djordje's solution does make all the trees the same.
