2011-03-04
12:27 AM
2023-05-24
11:51 AM
Rubia Torres
! DECLARATIONS
mID = ""
Q_ID = ""
Oc_Source = ""
Ps_No = ""
Ps_OSCrank = ""
Gade = ""
Oc_Name = ""
Psn_Status = ""
PsnChangeNote = ""
Ofice_Type = ""
Pl_gl_verbal = ""
At_Sts = ""
DIM STF[1000][12]
STF[1][1] = ""
i_m = 1 ! This must be initialized to 1, otherwise
! INPUT stmt below will cause
n1_m = 0
ch1_m = 0
file1_m = "STFSTUF.txt"
file2_m = "STFSTUF_DataValidation.txt"
! WORK
ch1_m = OPEN ("TEXT", file1_m, "SEPARATOR='\t', MODE=RO, LIBRARY")
DO
n1_m = INPUT (ch1_m, i_m, 1, mID, Q_ID, Oc_Source, Ps_No, Ps_OSCrank, Gade, Oc_Name, Psn_Status, PsnChangeNote, Ofice_Type, Pl_gl_verbal, _At_Sts)
STF[i_m][1] = mID
STF[i_m][2] = Q_ID
STF[i_m][3] = Oc_Source
STF[i_m][4] = Ps_No
STF[i_m][5] = Ps_OSCrank
STF[i_m][6] = Gade
STF[i_m][7] = Oc_Name
STF[i_m][8] = Psn_Status
STF[i_m][9] = PsnChangeNote
STF[i_m][10] = Ofice_Type
STF[i_m][11] = Pl_gl_verbal
STF[i_m][12] = At_Sts
i_m = i_m + 1
WHILE n1_m > 0
CLOSE ch1_m
2011-03-04 05:16 AM
2011-03-04 03:55 PM
2011-03-04 04:04 PM
2011-03-04 04:24 PM
2011-03-16 09:37 AM
didrik wrote:I don't see these
On the main's CALLing side, I have sent over values fromrowsto rows_mand from colsto cols_mand have used the CALL stmt with RETURNED_PARAMETERS STF. The range of resulting error messages indicates some fundamental misunderstandings on my part, somewhere.
didrik wrote:I guess not. It plainly disables the running of all other scripts of the macro object (which, I guess, was your intention).
I wonder if END is a problem here in the macro's Master Script?
didrik wrote:Don't be bothered by the character case of the parameter name - GDL isn't either. Achieving case-insensitivity is done by making everything uppercase inside, hence the uppercase reference in the error message. On the other hand, ArchiCAD surely has a reason not to find that parameter. There can be several reasons for that: mistyping the parameter name at any point, calling a different macro than you're looking at or the parameters having incompatible types.
One point is that the CALLing object error message switches the case of the variable: it says thatCOLS_Misn't a valid parameter name and cites the CALL stmt. I'm not sure what's not valid about it, since it(s lowercase version) plainly exists in the macro. Normally variables are cited back in the same case as they occur in the scripts, even if underneath case doesn't matter.
2011-03-16 11:47 AM
