2007-11-27 05:06 PM
2007-11-27 05:44 PM
2007-11-27 06:14 PM
2007-11-27 06:36 PM
2007-11-27 07:07 PM
Alice wrote:Don't delete your grid, but you'll probably want to check your parameters after the update.
do i need to delete the old grid and start from scratch, or should the udpate just "fix it"?
Alice wrote:Grid Dimension settings are located in the Marker dialog. Make the desired S/E Tool active and Ctrl+A to select all Markers of that type in plan. Make sure dimension parameters are off under the Grid Tool panel.
what's the best way to edit the grid and tell it not to include dimension strings?
2007-11-29 04:49 PM
2007-11-29 05:31 PM
2007-12-10 05:14 PM
weird problem #1:Alice, are you still having this problem? My office is, too, but it's primarily concerned with palettes. Nobody here has found a solution yet, though.
we've been having issues with our work environments "sticking,"
1) When we return to our elevation views we're getting multiple dimension strings....5 or 6 in the same place. If we delete them, they'll show up again later on.And how about that one? The next time it happens, save a separate copy of the teamworked file somewhere on your server. GS in Budapest would probably be very interested to have a look at it.
2007-12-11 02:52 AM
2007-12-11 04:33 PM
