2007-11-27 05:06 PM
2008-05-07 01:26 PM
2008-05-08 01:26 AM
Djordje wrote:Sorry to go back to an old part of the question, but we still can't find a way to stop the grid tool refereshing in sections. The attached shows how we used to achieve it but I can't find where the setting has now been hidden.Matthew wrote:...
Djordje,
This is exactly how we used to do it in V10. However I cannot find the ability to change the Grid tool refresh in the V11 Section Settings. Where have they moved it to?
Matthew Johnson
Powe Architects
The setting is there, I can't remember where at the moment, and all the dongles are at the office ...
2008-05-08 05:36 PM
2008-05-09 12:42 AM
2008-06-05 04:30 AM
2008-06-05 04:24 PM
sanderarchitects wrote:I've never seen this, but would recommend that once the Grid System is somewhat established, you edit individual Grid
In AC10, my problem is that I can make a rectangular grid with "Grid System" and put it in place. Then if I want to modify the grid, maybe insert an additional gridline for example, I select the whole grid, go into "Grid System Settings", and it changes my grid into a square. Even if I don't change anything. There is a setting in "grid geometries" to set the length of the line, but I want my horiz. to be one length and my vert to be another length. The left is before I opened and oked Grid System Settings.
2008-06-05 06:45 PM
2008-06-05 08:06 PM
2008-06-10 08:38 PM
sanderarchitects wrote:You should not.
ok thanks guys, I just got so excited about auto-updating the sequencing but I guess it's not a big deal. Most important is if I adjust the position of a gridline in plan, it is updated in section and elevation. Hope I don't have problems with that...
2008-06-12 08:12 PM
