Guidelines to create Opening Lines in 3D for doors/windows?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2013-01-08
09:31 PM
‎2023-05-24
12:35 PM
Rubia Torres
My searches on this topic were not successful.
Does someone have any tip on how to create 3d opening lines that show in sections/elevations and schedules for my custom doors and windows?
Is it just a matter of adding LIN_ commands to the 3d script?
What global variable (if any) should I use to make these LIN_s only visible when "Show Opening Lines in 3D Projections" are selected in Model View Options?
Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-01-11 02:17 PM
Durval wrote:Yes, if all you want is a solid line. No, if you want a dashed line. The LIN_ command only creates a solid line. for a dashed line the routine is more complex, creating the appearance of a dashed line with a series of spaced solid lines. You can take a look at how the standard ArchiCAD windows and doors do this, and possible just copy the subroutine into your doors and windows.
Durval wrote:There is not a Global Variable, the MVO is using the parameter name to communicate with the library parts, (look at the Master Scripts of the ArchiCAD library parts for the command LibraryGlobal), so if you use the same parameter name as the ArchiCAD library you will be able to use the existing MVO without creating you own LibraryGlobal.
In both cases looking at the ArchiCAD library parts to see how they work should help.
David
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-01-17 03:22 PM
I will explore the ArchiCAD objects as you suggested (but only when I'm not in such a tight deadline to deliver my window schedule!).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-01-18 02:44 PM
Durval wrote:Good idea
David
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-01-18 03:12 PM
David wrote:You always think you will solve things in less time that it is actually needed, but you keep going, telling to yourself "if I make a good tool, I'll save a lot of time in future"
Good ideaGDL can be a rabbit hole.
David
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-05-15 12:15 AM
ArchiCAD USA 28-Build 3110 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-05-15 01:43 PM
rgarand wrote:No. The other door options (frame, opening lines, etc.) will still be available, you are just adding a custom leaf to the door part.
Is this the sort of thing I need to understand if I am creating custom door PANELS and want to show the opening lines too?
David
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-05-15 05:05 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-05-16 02:00 PM
Works here. A few things to try:
1. Do the opening lines appear if you change to one of the standard door panels and leave all the other parameters as is?
2. Try viewing the door in 3D, Wireframe Mode, and see if the lines appear, maybe they are inside the door panel.
David
