JGoode
HPrism Contour Lines
I want to remove the contour line shown in the attached image but I want it to remain in elevations. It seems to have worked for the rest of the lines that I want but not the square on top.
HPRISM_ mat_prism, mat_prism, mat_prism, mat_prism,
	17, (ZZYZX/2), 0,
	chamfer, 1,
	chamfer,		0,			78,
    (A-chamfer),	0,			78,
    (A-chamfer),	chamfer,	900,
    0,				90,			4001,
    A,				chamfer,	78,
    A,				(B-chamfer),78,
    (A-chamfer),	(B-chamfer),900,
    0,				90,			4001,
    (A-chamfer),	B,			78,
    chamfer,		B,			78,
    chamfer,		(B-chamfer),900,
    0,				90,			4001,
    0,				(B-chamfer),78,
    0,				chamfer,	78,
    chamfer,		chamfer,	900,
    0,				90,			4001,
    chamfer,		0,			78
ArchiCAD 27
Windows 10
11 Replies 11
runxel
Just a short reminder that you can avoid some issues if you do something like this:
! 3d script
mask = 0
! section or elevation
if GLOB_VIEW_TYPE = 4 OR GLOB_VIEW_TYPE = 5 then
	mask = 1    ! your desired maskvalue
endif
You will then use "mask" instead of a fixed number – now you can have different lines in different view types.
JGoode
! 3d script
mask = 0
endif
Thanks very much, didn't even consider this. I was so focused on getting the mask to work correctly!
ArchiCAD 27
Windows 10
