Help! Where is my tabletop!
I'm following the ArchiCAD Guide - GDL chapter 8. I have created a table by scripting. When I'm going to test it, the tool settings dialog box 3D-view shows the table correctly.
But, when I put an instance of it in the floorplan, only the legs are visible in the 3D-view. I don't know where to look for the error.
Please help!
David Maudlin
Anne:
Why don't you post the part to the Forum, so we can take a look at it. The only reason I can think of for this behavior is that you have enabled the 3D Cutaway for the 3D Window.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I was about to find the librarypart and post it. To test it in AC one more time, I reloadet it from the filesystem. And, suddenly the problem had disappeared. Now I can see the whole table.
