Hidden line trouble
Hi everyone. I am having trouble showing objects below other as hidden / dashed lines. I have seen a tutorial that creates a 3d document and activates "show hidden edges", but does one show hidden object correctly in plans, sections & elevations?
TIA
1 REPLY 1
Podolsky
Ace
The function "show hidden edges" works only is 3D document.
It floor plan there is appeared new feature in ArchiCAD 23 (controlled via model view options), that able to show beam with hidden line, if it's located under the slab.
There is no similar function for sections or elevations.
