Hide text of objects.
AndreGaspar
Hi!
Some objects have text (label) on them. Is it possible to hide this text on some views?
Operating system used: Mac Intel-based Sonoma 14.2
Hi @AndreGaspar
I see, so you want to be able to hide it by view...
I think the easiest way to do that will be to uncheck the "Text" option and use a simple text or label for the property of your choice to display in those views you need.
Regards
M. Arch. Ricardo López
AC17-28 SPA+INT | Windows 11 | MSI CreatorPro M16 HX C14VJG, 64GB, Nvidia Quadro RTX 2000 Ada Generation
4 REPLIES 4
Ricardo Lopez
Hi @AndreGaspar
Can you name one of those objects as an example for your question?
Most of the objects with text/ label have an option to hide it or change it to none.
You can also check if those labels have their own layer to disable.
Regards.
For example, the fridge object. It has this text parameter that will label the object.
I´ll like to hide it in some of the views.
Hi @AndreGaspar
Regards
Hi
Yes, that's what I was afraid of. There are many objects to change.
Thanks.@Ricardo Lopez 🙂
