ArchiMind
Hotlink module override windows setting
Hello
Upon working with hotlink modules we encounter the unusual behavior. The window reveal that has been set in the module file in host files behaves strangely. It overrides the reveal and turn in skin settings. Is this possible bug, or is there some setting that could prevent this behaviour? 
Versions 13 to 25
CPU: AMD Ryzen 9 5900X 12-Core
RAM:32GB
GPU: RTX 2080Ti
Windows 11
3 Replies 3
Lingwisyer
Guru
Just to clarify, these are standard AC parts?
ArchiMind
Yes
Versions 13 to 25
RAM:32GB
GPU: RTX 2080Ti
Windows 11
Marc H
Looks like an auto skin wrap is running long and covering over the custom ‘thin’ facade return.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
