‎2011-09-06 09:37 PM
‎2011-09-06 11:16 PM
‎2011-09-07 12:04 AM
‎2011-09-07 02:19 PM
‎2011-09-07 04:59 PM
David wrote:Hi David, but this would be just to insert a Title by it self on a page or drawing right? (Correct me if I am wring Please).
Another way is to go to Open Object by Subtype, then navigate to Drawing Symbol > Drawing Title >name of title, this will allow you to see and open the built-in titles.
David
‎2011-09-07 05:05 PM
andro55 wrote:Hi Andro,
This object (Drawind Title) is named "Title with Layout No 11.gsm" in AC14 INT.
I extract "ArchiCAD Library 14.lcf" but there isn´t that object. But I found it in the ACE library "04 ACE-Library-V1"!
Modify it (have a good luck); Save as...; Select an exsisting Drawing title and change it with another using "Load Other Drawing title...".
‎2011-09-07 05:10 PM
Karl wrote:Hi Karl,
Select the title first, then ctrl-shift-O / cmd-shift-O to open - or File > Libraries and Objects > Open Object...
‎2011-09-07 05:39 PM
fransole wrote:Hi Karl,Karl wrote:Hi Karl,
I tried to do that in one of my drawing's TITLE in the Lay Out Book but nothing happened. Am I suposed to do the steps you described some place else? Tks,
F.S.
‎2011-09-07 07:50 PM
fransole wrote:Hi Francisco,
Just to try to understand how this GDL interface works, I assigned a different color to each one of the "little pen icons" and saved it with a new name so i dont mess the original one.
Back to the drawing in the Lay Out Book I assigned that new TITLE but nothing changes in terms of colors and or thickness. Am I missing some stem in here? Tks Karl.
F.S.
‎2011-09-08 01:45 AM
