How can I customize a DRAWING TITLE?
I went to Edit GDL Library Parts, and "clicked" on Open Object, but I couldn't find where those library marts are stored.
Any idea if this is the right way to doi it and if it is. where are the Titles stored? Thank you.
F.S.
14 REPLIES 14
Select the title first, then ctrl-shift-O / cmd-shift-O to open - or File > Libraries and Objects > Open Object...
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
This object (Drawind Title) is named "Title with Layout No 11.gsm" in AC14 INT.
I extract "ArchiCAD Library 14.lcf" but there isn“t that object. But I found it in the ACE library "04 ACE-Library-V1"!
Modify it (have a good luck); Save as...; Select an exsisting Drawing title and change it with another using "Load Other Drawing title...".
David Maudlin
Another way is to go to Open Object by Subtype, then navigate to Drawing Symbol > Drawing Title > name of title, this will allow you to see and open the built-in titles.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Hi David, but this would be just to insert a Title by it self on a page or drawing right? (Correct me if I am wring Please).
What im looking for is to modify the Title so all the titles already in the Lay Out book get changed at once automatically.
Hi Andro,
The file I am trying to modify or duplicate and then modify is NSC Drawing Title 2 15
I went to Graphisoft/ ArchiCAD15/ ArchiCAD Library 15 but don't see any ACE Library. Can I use the file you've attached? How & Where can I insert it?
(See attached File stucture of ArchiCAD 15 Files...
Thank you,
F.S.
Hi Karl,
I tried to do that in one of my drawing's TITLE in the Lay Out Book but nothing happened. Am I suposed to do the steps you described some place else? Tks,
F.S.
fransole wrote:
Hi Karl,
F.S.
Hi Karl,
Just to try to understand how this GDL interface works, I assigned a different color to each one of the "little pen icons" and saved it with a new name so i dont mess the original one.
Back to the drawing in the Lay Out Book I assigned that new TITLE but nothing changes in terms of colors and or thickness. Am I missing some stem in here? Tks Karl.
F.S.
F.S.
Hi Francisco,
Yes, if you changed all of the pen parameters in the GDL editor to what you want as your default pens, saved the object, and then switched the title on the layout to your saved-with-new-name object, the pens that you had set should show up. But, do note, that the pens for the title are the LAYOUT pen table, not the DRAWING pen table. (There is one pen table active for all layouts - each drawing can have a different pen table.) So, check what pen table is active for your layout -that may be what is amiss?
sinceV6
Hi.
If I'm reading right your needs, you are in AC13+ AND you don't want to mess too much with the underlying GDL you can:
1) change the title type in the drawing's properties to "Stamp title". It'll give you "just the circle" like you want (said in attachment), and enough parameters to change linetype.
2) you can always use the drawing tools and autotext to make a custom title. check the documentation on how to create them, depending on your version
http://www.graphisoft.com/support/archicad/documentation/
for ac15 int here:
http://www.graphisoft.com/ftp/publishing/ac15_help_INT/Files/wwhelp/wwhimpl/js/html/wwhelp.htm#href=...
check the part that says "create new title type" You basically draw your title to scale, and use autotext to reference info from the placed drawing.
As for changing every title, if you make one, or open (from library) edit and save, and then change something and re-save; every title using the library part will be updated; if what you want is to change title type for already placed drawings, you can use the drawing organizer to do this in a batch style; just be careful not to change anything you don't want to update in every drawing.
Best regards.
