2008-12-03 06:38 AM
2008-12-03 07:18 AM
2008-12-03 11:59 AM
Patrick wrote:If you want a quick and easy way to do this, take a look at OBJECTiVE. It can automatically add everything required for an object to be rotated (or cut) in 3D, and provides visual tools to apply the operations. Referring to the attached image, you would only need to:
In the attachment, I need to tilt the outhouse about the "x" axis, so that the top lays down toward the observer. Is there a script that will do that?
2008-12-03 05:15 PM
2008-12-03 05:45 PM
2008-12-03 06:16 PM
2008-12-03 07:14 PM
2008-12-04 02:30 AM
Patrick wrote:Sorry I didn't really think about the position you may have saved the object from.
Ooo... Thanks for the scripting tip. It worked for me fine, sort of. I have attached the result, but was surprised. My expectation was that it would have simply rolled down on it's side about it's x axis, but instead, as you see, it kicked up and away, as if the axis was 20' or so higher. Would this have anything to do with having 'built' the original model some place other than at 0/0?
2008-12-04 11:00 AM
2008-12-04 11:02 AM
