2023-07-06 05:44 PM
How do I optimize my PLN from embedded surfaces using container library?
I have created 100+ of surfaces so I can save as template for future projects. How can I make these surfaces in the embedded library as container library in such a way that the actual Solo Project PLN space will reduce?
Is there a way that every future project I start I’ll be able to link it with the surface container library saved in a permanent location in my pc without it adding all that data weight to the PLN? I’m trying to optimize space.
Every project I have now is 18GB average because they all have those surfaces embedded in it.
2023-07-06 06:11 PM - last edited on 2023-07-07 03:47 AM by Barry Kelly
If I understood the question, see if this is what you want:
https://community.graphisoft.com/t5/Libraries-objects/How-to-create-a-Library-Container-File-LCF/ta-...
