Gytis
How show shutters in the shedules as separate item?
There is one issue about showing the shutters. They aren't shown in the shedules although windows and doors are shown.
Is there any way to show them with the windows and doors? Or maybe is there any method show the shutters as separate items?
1 Reply 1
If the shutters are part of the window and door objects, then they are scripted in a way so they do not show.
Whether this will ever be fixed or not we just won't know until it is done.
https://community.graphisoft.com/t5/Wishes-forum/Shutters-in-SCHEDULE/m-p/229709
You can fix this yourself if you want to go diving into the GDL scripting of the objects.
But be aware you will always have to use this amended library.
As soon as you switch back the the default Graphisoft library, you will have the no shutter problem.
https://community.graphisoft.com/t5/Collaborate-forum/Doors-Windows-view-in-Interactive-Schedules/m-...
I have no idea why part of Daniel's solution has the text struck through - I tried to change it but couldn't.
