Object visibility based on relevant stories
I want to set the home story for all objects to the top most story, which i can do using relink home story. But, then these objects are visible on its home story only. I want these objects to be visible on its relevant stories based on its story range link the way elevator object is working / HEA Column 17 is working.
Please find the attached file for the object which i am referring to.
3 Replies 3
I got the solution from other post and its very simple. The issue is solved now.
Can you tell us what the solution was or link to that other post?
Other might find it useful in the future.
karinarojasmarin
Hi, how did you solve the issue? I have an object set to show on relevant stories that I want to show on a story above that has its floor plan cut plane settings configured to show the stoy below. The only way I get it to show is when I change it to show on home story and story above, but the it shows on another bunch of floor plans where it shouldn't, I only want it to show on its home story and a specific floor plan above with its respective floor plan cut plane settings.
Screen Shot 2022-10-29 at 11.59.34.pngScreen Shot 2022-10-29 at 11.57.51.png
