How to Fix Rhino file be converted to Mesh (polygon) when import GDL?
Hi
I used this method to import Rhino file to ArchiCAD
Method 1
1. Go to File > Libraries and Objects > Import Rhino 3DM File as Object...
2. Select the 3DM file to import and click Open.
But the model be converted to Mesh (polygon). It make my model is not smooth. Please view attached file for more detail.
How can I fix it?
Best regards
Travis
2 Replies 2
mikas
Did you look at import settings?
https://helpcenter.graphisoft.com/user-guide/65777/
AC28, Rhino8+Grasshopper, TwinMotion • Mac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RTX4080FE 16GB/W11ProWS
Hi mikas,
thank you. It's work better.
