zidaneasyad
How to Migrate Custom Library into New Device?
I was using AC'28 in my laptop back then, and now i can afford a PC and installed AC'29, when i opened the old .pln file on my new pc the model and plan has missing custom library (custom door/window etc.) is there any specific file i can copy to my AC'29 directory from my old laptop so the library stay intact?
Setup info provided by author
1 Solution
Yes you need to copy the folder that contains all of the library objects.
If you look in the Library Manager, it will tell you the library that is missing.
You need to find that on your laptop and transfer it to your PC.
Then load that folder as your library.
Go to post
2 Replies 2
Lingwisyer
Guru
If your file structure between computers is identical, it will automatically map once you have copied the relevant folders across. If not, you will need to re-add your custom library folder. Once done, the objects will resolve themselves.
Ling.
