Read more
How to add downloaded objects?
i have downloaded some objects( from www.archibase.net ) i don't know to add it correctly. The objects are in .gsm , .3ds format. the shape appears but the texture don't, everthing is gray. I use archicad 11 EDU, and i add it with objects->Load other objects->from file dialog box.
Thanks for the help
Snowking
7 REPLIES 7
That should work.
Is it possible that the object is in AC12 version format?
I have the same problem.
What is EDU?
David Maudlin
cadaron wrote:
What is EDU?
The educational version of ArchiCAD.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
rocorona
This is almost normal, because gsm objects on archibase are often translated from 3ds files, without material definition.
And thy are very very heavy.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
laszlonagy: magyarul is beszelhetunk:) (we can speak hungarian)
rocorona: how can I add textur? (I have a downloaded folder with .tga files. I think they are the textures) Or where can I download (free) objects with material definition.
You will need to open up the library part to see exactly how (and if) the materials are defined.
This thread may help - http://archicad-talk.graphisoft.com/viewtopic.php?t=24240
Also there are lots of objects in the object depository here - http://archicad-talk.graphisoft.com/object_depository.php?
Igen, bár a többi olvasónak kicsit elkerekedne tőle a tekintete.
(Yes, although other readers would get slightly googly eyed.
