How to add window & door on curtain wall?
Is that any way to replace unnecessary panels of the curtain wall with window or door?
2 Replies 2
David Maudlin
Kent:
Select the Curtain Wall, click on the Edit in 3D button, select the panel, open its dialog box, select one of the cw windows or doors from the Panel Type pop up list. These will be curtain wall objects, not the doors or windows used in walls. If you want to use the standard windows and doors, delete the panel, place a wall that matches the opening, then place a standard window or door.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you!
David wrote:
Kent:
David
