2011-04-12 09:01 PM
2011-04-12 09:10 PM
2011-04-12 09:56 PM
2011-04-12 10:58 PM
2011-04-12 11:20 PM
2011-04-13 01:02 AM
2011-04-13 01:48 AM
2011-04-13 04:08 AM
2011-04-13 04:26 AM
2011-04-13 06:04 AM
Barry wrote:Right.
GLOB_CONTEXT=4 will determine if your object is being viewed in a section or elevation but it won't determine the direction that it is being viewed from.
So the microwave will look the same in every elevation.
The trick then is to hide the layer of the object in side / rear view elevations if you don't need to see it in those.
If you do need to see it from all elevations then I think you are back to adjusting the code from the original object if you can to simplify it.
