The GDL script itself is not that complex for making 3D text, however I don't think there is an option to wrap words to one letter per line. You would have to break up the text in to multiple lines or PARAGRAPH for the GDL command. After this you can just make a TEXTBLOCK with the paragraphs and use RICHTEXT.
Refer to the GDL Reference Guide available from the help menu in ArchiCAD.
A quick way to get script going is to type in a 'normal' 2D text and drag that from the plan view to 2D script window in a new object.
www.leloup.nlArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
