How to get a maximum value from array list?
Hello!
I have generated one dimendional array list, which has a different number of variables , depent from the case.
I tried different examples, but none of them work:
PARAMETERS max_value_from_array = MAX(array)
or
PARAMETERS max_value_from_array = MAX(array[])
To get the maximum value from an array you have to use the PUT and GET commands, eg.
PUT(array)
PARAMETERS max_value_from_array = MAX(GET(NSP))
Wesley
Thanks for the advice.
Now my code works correctly.
