2010-03-04
02:23 PM
2023-05-26
11:25 AM
Rubia Torres
2010-03-04 04:14 PM
2010-03-04 04:41 PM
2010-03-04 08:04 PM
2010-03-04 08:22 PM
2010-03-04 11:00 PM
Reeves wrote:Which platform are you using? Primarily, is it a 32-bit or 64-bit version of Windows? Check that you have downloaded the equivalent version of OBJECTiVE, i.e. 32-bit/64-bit. If you install the wrong version, ArchiCAD will refuse to load it.
I use AC 13 and downloaded the Objective-verson that should work with AC 13.
But it doesn't seem to work. It says the file is outdated.
2010-03-05 04:06 PM
2010-03-11 06:33 PM
2011-03-27 10:53 AM
2011-03-27 11:31 AM
Svensdotter wrote:If you have any problems with software from Encina, contact Encina directly for support through the contact page
Hi, I have the same issue with the installation of Objective. Only I have now tried both versions (64 and 32) and neither works so that is not the problem. Anyone have a clue as to what it can be?
