How to hide parameters
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2015-01-17 11:37 AM
‎2015-01-17
11:37 AM
can someone help
thx a lot
11 REPLIES 11
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-01-20 11:29 AM
‎2015-01-20
11:29 AM
Dave wrote:
Jensvs
You jumped over Erich's Comment.....
This says that if parameter1 is turned on, parameter2 is to be hidden. For this to work, parameter1 must be a boolean value.
For your desk you need to create a Boolean value for the doors and or drawers. If the only two options are drawers or doors then try something like this (assuming you are using a VALUES script in the master script)
Parameters
desk_type Abc
desk_drawers Boolean
desk_doors Boolean
Master Script
dt_1 = "Doors"
dt_2 = "Drawers"
VALUES "desk_type" "Doors", "Drawers"
Parameters Script
IF desk_type = dt_1 THEN
PARAMETERS desk_doors = 1
PARAMETERS desk_drawers = 0
ENDIF
IF desk_type = dt_2 THEN
PARAMETERS desk_doors = 0
PARAMETERS desk_drawers = 1
ENDIF
Then you set up what parameters you want hidden or showing based on the values of desk_door and desk_drawers
IF desk_drawer = 1 THEN
HIDEPARAMETERS .................
ENDIF
Hope that helps.
Thx David
I have done what you said
But i have this code
IF Type_Drawer_Left = "Drawers" THEN
MATERIAL Material_Drawers_Left
IF Number_of_Drawers_Left = "1" THEN
BLOCK Width_Desk_Left, .015, Height_Desk-.105
ADDX (Width_Desk_Left/2)-.02
ADDZ .05
ROTX 90
MATERIAL Material_Handle
CYLIND .01, .004
ADDZ .01
ELBOW .02, 180, .004
DEL 1
ADDX .04
CYLIND .01, .004
ENDIF
and in the place of "Drawers" must be a number and i dont know what number
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-01-20 02:27 PM
‎2015-01-20
02:27 PM
Jens:
The code you posted should work, except you need another EndIf command as you have 2 If statements.
If you zip the object and attach it to your post, others will be able to look at the code without needing to guess at the parameters and other aspects of the object.
Thanks for adding the signature.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
