How to import a dwg city object inodiscreet archicad objects
Paul King
Mentor
Hi - I have a single dwg model of an entire city worth of buildings that I need to bring into ArchiCAD.
If I import directly, it comes through as a single huge library part.
However I need to be able to switch on and off individual buildings.
There are literally a thousand or more buildings in this model, and while each building is very simply modelled, selecting and saving each one out separately from AutoCAD is simply not an option
I need a way to automate the process and to end up with a thousand separate library parts or meshes or other corresponding entities in ArchiCAD
Help?
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-28 | Twinmotion 2024
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
4 REPLIES 4
Eduardo Rolon
If they are in different layers you could 3DSout them from autocad and choose that it separates the objects in the file by the layers. The same might work if they have different colors.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Paul King
Mentor
The buildings are all a single colour and layer in AutoCAD - and there are 1000 of them!
Eduardo Rolon
You can try one of these 2 settings to see if they help. If I remember correctly one "might" create individual objects based on the 3D Information.
AC28 US/INT -> AC08
another Moderator
Paul King
Mentor
I have found another way that definitely works!
First open the dwg file in Deep Exploration, select all and use CADTools/Separate meshes command, then open file in AutoCAD Architect or other package that can export to IFC, then import IFC into ArchiCAD.
Result is all objects brought in as separate entities, in one hit.
