There are a lot of web sites with archicad libraries, but no manual of "how to" update or import these libraries in archicad. I copy full folder with models into archicad Library folder and no it is no use. Sorry for such a newbie question but i haven't found smth about it directly.
If you already have Archicad running when you copy the new library parts to your library folder then you will need to "Re-load" the library in the Library Manager.
Otherwise re-starting Archicad and ensuring the correct library folder is loaded should do the trick.
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
Andrejucad wrote: I copy full folder with models into archicad Library folder ...
Andrejucad:
You should not copy these parts into the ArchiCAD Library, as they will be deleted if the ArchiCAD Library is updated. You should use the Library Manager to add theses additional libraries to your project.
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro OSX14 | 36 gb ram
I have archicad 13 and house plan made in archicad 7. I installed archicad 9, saved as 8.1 that old pln, then, i opened it in archicad 13. Doors, windows, furniture are missing library ( 7.0 library). One good samaritan gived a download link on archicad 7 library, i downloaded it, extracted in new folder and i don't know what to do next. How to make visible symbols in archicad object library (not manually) like i choose objects in left corner ( standard clicking what do i need or like). Or how to update this library to to make dissapear green, orange dots (missing parts) at once?
sorry for porrige
P.S. i saw an LCF file in archicad folder, when i click it i can see all object folders in left corner ( visually) but in this 7.0 library ( which was extracted in new folder) i see no lcf file
For information about library management with images, go to Help > ArchiCAD Help, when your browser opens click on the "Search" tab, and input "Library Manager" in the search box, in the results list "Library Manager" will lead to detailed information. You can also search this forum.
