Streamline your workflows and master BIM coordination! Program starts April 28.!
Importing and Cleaning up Objects in Archicad
JaredBanks
Mentor
There's a bunch of ways to clean up/create Objects in Archicad. Here's a link to my recent blog post and YouTube video showing how to take a SketchUp object, explode it into a morph, clean it up, and turn it into a Archicad object with a good 2D symbol:
http://www.shoegnome.com/2023/10/23/archicad-tutorial-95-importing-and-cleaning-up-objects-in-archic...
And here's a link to the YouTube video itself, if you want to skip the additional info in the blog post:
https://youtu.be/cU4gNFADZm8?si=5xK0plk9EkhF0sSY
Jared Banks, AIA
Shoegnome Architects
13 REPLIES 13
DreamHost is supplying free certificates via Let's Encrypt. You just need to go through the process and add it to your domain. A quick search presents an article from DreamHost about how to do it.
DGSketcher
Legend
@JaredBanks Back to your OP, you could also combine everything you have shown with the Library Part Maker add-on to generate objects with MVO controlled detail if that was relevant to the SU model and user requirements.
I haven't looked at LPM in way too long. I'm looking forward to hearing James Murray talk about it this afternoon during his Archicad by the Beach presentation. We had a presentation on Modelport 3.0 yesterday and that looks really promising for similar import needs.
Jared Banks, AIA
Karl, Thanks for pointing this out. It was the kick in the <redacted> that I needed. I got the SSL certificate all set up this morning. Everything should load properly for you now.
Jared Banks, AIA
