Teamwork Libraries Appearing as Local
This has puzzled me for a while, occasionally on files, within the library manager, instances/references to BIMcloud libraries show as local missing libraries.
If a user opened a file on a device that didn't have access to the teamwork libraries, they normally just show up as missing.
Does anyone have any idea what's causing this?
Examples below of issue file and template file.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
First step what I should do is clean up libraries in "Local data manager" also ask another person who don't have access to BIMcloud to do that.
How that another person opens file ? Is separate *.PLN or *.PLA or Teamwork file ?
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v29 INT / NOR
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
scottjm
Mentor
This just happened to a user in our office on a solo PLN with Teamwork libraries loaded in.
No rhyme or reason I can tell.
Did you identify any cause when it happened to you Josh?
