Importing and Cleaning up Objects in Archicad
There's a bunch of ways to clean up/create Objects in Archicad. Here's a link to my recent blog post and YouTube video showing how to take a SketchUp object, explode it into a morph, clean it up, and turn it into a Archicad object with a good 2D symbol:
http://www.shoegnome.com/2023/10/23/archicad-tutorial-95-importing-and-cleaning-up-objects-in-archic...
And here's a link to the YouTube video itself, if you want to skip the additional info in the blog post:
https://youtu.be/cU4gNFADZm8?si=5xK0plk9EkhF0sSY
Jared Banks, AIA
Shoegnome Architects
Archicad Blog: www.shoegnome.com
Archicad Template: www.shoegnome.com/template/
Archicad Work Environment: www.shoegnome.com/work-environment/
Archicad Tutorial Videos: www.youtube.com/shoegnome
13 Replies 13
Lingwisyer
Guru
DreamHost is supplying free certificates via Let's Encrypt. You just need to go through the process and add it to your domain. A quick search presents an article from DreamHost about how to do it.
DGSketcher
Legend
@JaredBanks Back to your OP, you could also combine everything you have shown with the Library Part Maker add-on to generate objects with MVO controlled detail if that was relevant to the SU model and user requirements.
I haven't looked at LPM in way too long. I'm looking forward to hearing James Murray talk about it this afternoon during his Archicad by the Beach presentation. We had a presentation on Modelport 3.0 yesterday and that looks really promising for similar import needs.
Jared Banks, AIA
Karl, Thanks for pointing this out. It was the kick in the <redacted> that I needed. I got the SSL certificate all set up this morning. Everything should load properly for you now.
Jared Banks, AIA
