Industrial MEP components
Hey there all,
A new members first post!!?!
* I have ArchiCAD 13 installed + MEP plugin.
* I have an ArchiCAD model of a 12 story building.
* I have to run all MEP services through each level.
* I have .dwg files of the 2D layout for each level.
* I have a list of products used.
* I need to create 3D deliverables of each floors services.
I am completely new to ArchiCAD (yes it is that bad) and have AC13 and the MEP plugin for 13.
I have figured out how to use the MEP tools, my problem is that all the MEP equipment seems to be residential.
I have found most of the componentry on a suppliers website. Available formats are dwg/dxf, Revit, CATIA, 3DS Max.
Is there a way of creating ArchiCAD MEP equipment from any of these formats? Or is there anywhere to obtain industrial units?
Thanks in advance!!>!
5 Replies 5
Erika Epstein
Create your own elements and save them as MEP parts, similar to creating library parts
You can import the 3DS objects.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Can you direct me to any tutorials on making my own parts, and how to turn them into MEP parts that work?
P.S. I am having trouble with ductwork terminals.
I have set the duct connection to 'rectangular'. There is still a circular hole being extruded into the terminal unit. If the (A)Width value of the connector is bigger than the (B)Height value of the connector, a hole appears in the top of the terminal unit as the extruded hole is bigger than the unit. Is this a bug, or am I missing something??!?
Here is an Introductory Video Tutorial about creating objects:
http://www.graphisoft.com/education/training_guides/#GDL
Thanks for the tip!
