Inverted Opening Lines in Elevation
Laura Yanoviak
This is the Storefront Double Door (haven't taken the time to test others yet) -- in the file I'm currently working in, the opening lines appear inverted:
1 REPLY 1
Laura Yanoviak
Now, I open up a New file (use a template), cut/paste the same wall/door, and the result is correct: Yes, same exact Libraries are loaded. What's up?
