Is there a way to change the size of a sink in a cabinet?
Is there a way to edit the sink size in millwork cabinets? I need a large single sink or a small bar sink and they don't exist in the selections. A single sink would work fine if I can edit its size. The dimensions I can edit are for the cabinet itself, not for the sink. I needed a triple sink in the kitchen of a school I am building so I drew it in 2D rather than fight my way through putting a sink in a counter top and so forth. Any ideas?
1 REPLY 1
Stress Co_
Which base cabinet are you using? "Cabinet Base 3D 13"?
I don't see a parameter to change the sink size (pretty lame), but you could select "none" for the sink and place A "Multi Style Sink 13" on the cabinet. You'll have to SEO the sink from the cabinet if you want to see "into" the sink in 3D.
Marc Corney, Architect
Red Canoe Architecture, P. A.
