Karol Argasinski
Issue with Library Part Maker Libraries (AC28)
Fellow Users,
After installing LPM for AC28, I've run into issues with Libraries and templates. The add-on cannot run without them. It worked for me in previous versions, but no luck now. How proper install LPM for AC28 so it can be used right away? I want to make it a Teamwork file for Library objects.
Kind regards
Karol
OPENBIM does works!
ArchiCAD 22/23/24/25/26/27/28/29 INT &POL
AMD Ryzen 7 3700X, 128GB RAM, GeForce RTX 3070, Windows 11 Pro
MBP 14 M3 Max 16C/40G, 128GB, 2TB
http://www.bimfaktoria.pl/
3 Replies 3
Guru
There is a Library Part Maker.libpack
Karol Argasinski
Hi, where are those?
I can't find it on Mac.
OPENBIM does works!
Guru
In the installation folder under Archicad Library Packages
