Issue with OSX 10.3.3 and server llibraries
tsturm
Hello to all Mac users running 10.3.3 with libraries located on remote machines. Just ignore, those who are running Windows as I am sure you are unaffected.
I am attaching a picture of the before and after of the Library Manager window.
I, last week, installed the 10.3.3 update of OS X. Then I went to work on a new project. I opened a new file. Then went to attach our office library standards from our server. I found that I could see the server, but cannot open the arrow to see the directories to add the specific directory where our parts are.
I can run projects which have the libraries already attached. They load fine. I cannot add any additional libraries to projects. I am having to have others add the libraries for me, save and close the file, so I can work on them.
Is there anyone else having the same problem. I thought this might be an existing file problem. So I did a New & Reset. Nothing has changed. Should I trash my preference file?
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
33 REPLIES 33
__archiben
ah. not the same problem as mine.
what permissions do you have on your applications folder? see screenshot and see if it's anything like mine.
also: i take it you've re-launched archiCAD?
~/archiben
undefined
b e n f r o s t
tsturm
Ben
I am back to seeing the contents of the Applications folder.
Here is what I did to get it working.
1. I created a new folder called Temp Apps. I moved the entire contents of the Applications folder to this folder after making sure all the applications had been quit.
2. I moved the Applications folder to the Trash. (did not emtpy the Trash, you need Admin access to do this as this folder is part of the system)
3. Changed the name of the Temp Apps folder to Applications.
4. I restarted and did a PRAM reset by holding the Option, Command, P and R keys at the same time for a rechiming of three sets. (remember C.R.O.P)
5. I then started ArchiCAD and opened a new project. I opened from a Template to get the NEW & RESET verison. (pulsing button now reads NEW & RESET)
After doing all these, I am now seeing the contents of my Applications folder and all the sub directories.
My settings are the same as yours with the Everybody having Read & Write permissions.
Try my method out by creating a new folder where the one which is giving you a problem.
HTH
Still waiting for GS to chime in on this problem.
_______________
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
__archiben
terrance
thanks. yours wasn't the same issue as i was having.
glad to hear you've got it fixed.
~/archiben
b e n f r o s t
fuzzytnth3
tsturm wrote:
If you want another library, say of casework from Cabinet Builder, you need to load it via the Library Manager. But these additional libraries for our office are on a remote machine. I have not been able to add these libraries since upgrading to 10.3.3.
Is anyone else seeing the same problem in the same way. Not via the Finder, but through ArchiCAD?
TFHO
If it's any consolation I am having the same problem I can sometimes get to the Library that I need from the "History" tab but not in every case.
What I have found is that you can browse to an alias of the Library on a remote server by using the path to my user Home directory eg.
2-Graeme:Users:graeme:Desktop:Street & Traffic Library:
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
