I am back with news on how to get this all to work and possibly why I had the problems I was having.
Let me start out by stating that this issue is with the XServe by Apple.
If you are using a pier to pier file sharing system, you most likely would not find this problem. This issue is with the manner in which we chose to make the information on the "server" available to all the users. We permitted the users to log into the "server" as the administrator. There by giving them total access to the "server". I am not sure if this was the problem, but some how is must be.
I experimented with logging into other computers on the network to see how AC was reading those drives and the way the sharing was reading the different drives. What came out of this was you can gain access to the mounted partitions from inside of AC via the library manager only to the user area of the "server" and not the administrator level.
Let me break this down some more. When you log into a remote machine, not an XServer, just an machine, you can access the root level portion of the "server" and a user level. On a Mac OSX machine, there are different areas of the machine. When you try to access these different areas from within AC's Library Manage, only the mounted partitions which are not accessing the root level will work.
Ben had stated in one of his posted that the volumes were "share points". So it took me some time to figure out how to configure the XServe to change the sharing properties of the contents so that I could then access these "share points". This all had to be done from within the Workgroup Manager application which comes with the XServe. Once I had made the "share points", like making a folder as a shared volume under OS 9 instead of the entire hard drive.
Now I can access these "share points" from within AC's Library Manager. More importantly, I can attach my libraries to new projects.
I can add more information to this topic if someone should need screen shots. I don't think may people will have this problem as I hope everyone out there with an XServe has theirs configured correctly.
HTH.
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
