TracyGA
Joist Hanger missing in 21 [USA Detailer library]
Does anyone know why ArchiCAD got rid of the joist hanger library part? We were just looking for it in our office and realized it is no where to be found in ArchiCAD 21.
11 Replies 11
This is a USA issue (these parts have only ever been in the US library).
Graphisoft US (not HQ in Hungary) did this for totally unknown reasons - just as they also only provided a 'commercial' template out of the box this year, rather than residential and commercial as in years past.
Contact your reseller to complain.
The workaround is to use the File > Libraries and Objects > Extract a Container command on the AC 20 library LCF file to temporarily unpack the entire library into some folder (maybe call it AC 20 Detailer Lib) on your computer where you'd like to keep these symbols for future reference.
Remove everything from this folder EXCEPT the 00 General 20/Detailer Library 20 folder as well as the MACROS 20/Detailer Macros 20 folder. You'll remove more stuff in a bit.
If you want all of the missing 2D symbols, open Library Manager and add the folder above (AC 20 Detailer Lib or whatever you called it). You'll get a ton of duplicate part error messages because of the selected symbols that ARE in the AC 21 USA library. You can later eliminate those errors (you should) by going to the folder you created above and deleting the folder/content that corresponds to what IS in the AC 21 library in the 00 General 21 > 2D Details 21 folders. Crazy, but you'll see that while the original library has all kinds of masonry, the Masonry 21 folder only has what is in the CMU folder from the old library - so just delete the CMU stuff from the disk folder that you created. Etc.
After clean-up, the folder on your disk will contain all of the old stuff that isn't in the new 2D Details 21 folder. I have no idea if they improved any of those parts or why they chose to only include the random folders that they did.
vfrontiers
Ugh.
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
vfrontiers
And while we're complaining... why have these never been created as 3d Objects... Does no one else put joist hangers in their models?
Duane
Visual Frontiers
AC3.14 - AC29
vfrontiers
This gets more interesting...
I went to EXPAND LIBRARY CONTAIN and found that the SIMPSON stuff is IN the MIGRATION LIBRARY under AC20 parts..
But I can't SELECT them from the object tool...
hmmm.
Duane
Visual Frontiers
AC3.14 - AC29
vfrontiers
Soo... I couldn't LOAD the part, but I could "SAVE TO DISK" from the Library Manager (so I didn't have to extract the full library)...
Then, even after LOADING just that library, they were not available to choose from the object tool...
Then I just DRAGGED them from the FINDER (MAC speak)... onto the plan and it was there... I then opened the part and saved back to the folder as a 21.gsm and it's fine...
I am using these to create 3d Parts (with the ability to display them in a 2d window as FRONT and SIDE as well)
Duane
Visual Frontiers
AC3.14 - AC29
Thank You, Karl.
Aaron Bourgoin
Arghhhhh!
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
Rhino 8.34 Mac
MacOS Tahoe 26.5.2
Da3dalus
Has anyone created a replacement library for the discontinued parts, as Karl described, and published it? I could have sworn I saw one on a web site somewhere, but now that I need it for my updated Template, I don't see it. Graphisoft really should provide this.
Chuck Kottka
Orcutt Winslow
Phoenix, Arizona, USA
ArchiCAD 25 (since 4.5)
Macbook Pro 15" Touchbar OSX 10.15 Core i7 2.9GHz/16GB RAM/Radeon Pro560 4GB
Da3dalus
By the way, I created a Wish to bring back the objects here:
http://archicad-talk.graphisoft.com/viewtopic.php?p=272782&highlight=library+part+detail#272782
Chuck Kottka
Orcutt Winslow
