LABELS
ARE CUSTOM LABELS ABLE TO BE MABE STOREY SENSITIVE
9 REPLIES 9
Aussie John
Yes. Use GLOB_CH_STORY_DIST
eg if GLOB_CH_STORY_DIST>=1 then end
will not show the label if the storey is above the home storey.
Cheers John
[/size]
John
i have written a label that coverts a the height of o slab into brick coursing
& ffl measurements with the addition of a datum height
out method of drawing is that the slab is 1 storey below the storey where the brickwork sits & were the working drawing is completed
i dont seem to about to display the label on anything but its home story
i tried scripts such IF GLOB_CH_STORY_DIST=1 THEN GOSUB but could not manage to show the label on storey 1
i seemed to be able to trick into not showing anything at all by using
IF GLOB_CH_STORY_DIST<=1
Aussie John
is the slab only showing on the one storey? The label will only associate itself with a visible element
Cheers John
[/size]
in gerneral we will show the concrete slab on the storey above
hope were on the right wave length ive written the gdl part & loaded it
as a label. ive written many parts, like stairs were ive use the storey up storey down the manipulate the visual in the 2d script
im not sure if loading the part as a label is overriding these commands
Aussie John
It should work if the slab is visible
Cheers John
[/size]
john
this is the script that i used the label works fine in its calculation but
remains fixed on the home story
IF GLOB_CH_STORY_DIST <=3 THEN GOSUB 10
END
10:
IF glob_context=1 THEN
label_font_name="Arial"
label_text_size=2.5
label_font_style=0
label_text_pen=3
anch=1
ENDIF
DEFINE STYLE "textstyle" label_font_name,
label_text_size, anch, label_font_style
SET STYLE "textstyle"
height=J_
brkht=(600/7)*.001
Course=height/brkht
Brk=INT (Course+0.5)
h=INPUT_HT+ffl
DEFINE STYLE 'TXT' 'ARIAL NARROW WESTERN',2.5,4,0
SET STYLE 'TXT'
h=STR((height+ffl),5,3)
Brkh = str(brk,5,0)
stringLength=stw( " FFL" +Brkh +'c ' +'( ' +h +' ) ')/1000*A_
add2 0,0.25/2
add2 -stringLength/2,0
TEXT2 0.1,0, "FFL"+Brkh +'c ' +'( ' +h +' )'
PEN 15
del 1
RECT2 -stringLength/2,-0.3,stringLength/2,0.3
HOTSPOT2 -stringLength/2,-0.3
HOTSPOT2 -stringLength/2,0.3
HOTSPOT2 stringLength/2,-0.3
HOTSPOT2 stringLength/2,0.3
RETURN
Aussie John
Damien - I dont know - the script works ok for me.
Label shows on every storey (along with the slab) below the 4th storey above the home
EDIT I just noticed you are on v9 - from memory labels only show on the Home storey in v9
Cheers John
[/size]
thanks john
better start pushing for an upgrade
Aussie John
damien wrote:
thanks john
Yep v10 does have its gremlins but is a solid update
Cheers John
[/size]
