Using Building textures\ GDL objects?
I downloaded ''Building textures'' from (http://archicad-talk.graphisoft.com/object_depository.php). How I can use them in my archicad work?
4 REPLIES 4
Dwight
Textures make rendered surfaces look like materials.
Place the textures in a folder and load it with the library.
The textures will them be available to be used in new material surfaces you create.
Dwight Atkinson
Now I finally understand. Thank you very much.
New problem. I downloaded garden objects from (http://archicad-talk.graphisoft.com/object_depository.php) and I want to use them in my work. I tried open them from File menu and there GDL objects and open object but nothing opened when I selected object. Hope some can help me.
I get them into library now, but when selecting some objects comes warning:''Pen number is less than 1 or creater than 255 at line 3 of file Form_1_GWL.gsm.''
