Lamp and Light
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2009-06-17 05:12 AM
2009-06-17
05:12 AM
Thank you for your help.
13 REPLIES 13
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-24 03:36 PM
2009-06-24
03:36 PM
Good luck. Remember to work on copies of the original objects. Also, use the two I modified as examples and all should be well. If not, you know where I am.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-24 09:12 PM
2009-06-24
09:12 PM
Hi! I have an other question did you know how change the size of 2D symbol rcp?
Thanks
Thanks
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-25 03:46 AM
2009-06-25
03:46 AM
At least for the way the first part is written, the quick and dirty way is to define a parameter to scale the symbol, (ie "scale") and then add the following:
Attached is an fast example.
MUL2 scale, scaleJust before the line in the 2D script that reads as follows:
IF gs_detlevel_2D=`Electric Symbol` thenAfter the very last line in the 2D script add:
DEL 1In the parameter table you will need to add the parameter "scale" and set the type to be a real number.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-06-25 08:30 PM
2009-06-25
08:30 PM
Thank you so much.
I really appreciate you help
Thanks
Thanks
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
