Lamp and Light
Hi. Does anybody know how I can rotate the text in the object light when it's showing in the Floor Plan like a RCP symbol?
Thank you for your help.
13 REPLIES 13
Erich
Good luck. Remember to work on copies of the original objects. Also, use the two I modified as examples and all should be well. If not, you know where I am.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Hi! I have an other question did you know how change the size of 2D symbol rcp?
Thanks
Erich
At least for the way the first part is written, the quick and dirty way is to define a parameter to scale the symbol, (ie "scale") and then add the following:
MUL2 scale, scale
Just before the line in the 2D script that reads as follows:
IF gs_detlevel_2D=`Electric Symbol` then
After the very last line in the 2D script add:
DEL 1
In the parameter table you will need to add the parameter "scale" and set the type to be a real number.
Attached is an fast example.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Thank you so much.
I really appreciate you help
Thanks
